English
Error: Symbol "OCIEnvCreate unresolved" error when using ArcSDE on TRU64
Error Message
The following error message will most likely be displayed when trying to run the sdesetupora8i command at the UNIX prompt on TRU64 if the appropriate file settings have not been set in Oracle that enable all symbols to be exported:
"resolve_symbols: loader error: dlopen:
/usr/local/sde/sdeexe812/sdeexe81/bin/sdesetupora8i: symbol "OCIEnvCreate" unresolved"
Cause
Digital UNIX requires a list of all symbols that are to be exported from the shared library (libclntsh.so).
Solution or Workaround
  1. In the $ORACLE_HOME/rdbms/admin directory, open shrept.list in a text editor and add the line:
    rdbms : OCIEnvCreate
    immediately after the line:
    rdbms : OCIEnvInit
    Save the file.
  2. Rebuild the client shared library:
    cd $ORACLE_HOME/bin
    Type the following command: genclntsh
    You should then be able to build your OCI application using:
    make -f demo_rdbms.mk build EXE=progname OBJS="obj1.o obj2.o etc."
