HOW TO
Add Color Ramps to the Color Scheme and Color Ramp drop-down lists on the Layer Properties Symbology tab
Summary
More choices can be added to the Color Scheme and Color Ramps drop-down lists on the Layer Properties Symbology tab. See the Related Information section below for more information.
Procedure
The content of this article pertains to ArcGIS versions 9.x and earlier only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools. For version 10.x, refer to the Related Links section.
  1. Start ArcMap.
  2. Select Tools > Styles > Style Manager.
  3. Expand the ESRI.style folder and select Color Ramps.
  4. Select a style on the right-hand side.
  5. Click the Category name of the style.
  6. Replace the current category name with "Both".
[O-Image] Change Color Ramp Category to Both
  1. Close the Style Manager. The style will now appear in both the Color Scheme and Color Ramp drop-down lists.
Article ID:000005020
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
