English
Error: Unable to Find Layers in Image
Error Message
When using the Image Analysis extension to bring in an image theme, the following error occurs:
"Unable to Find Layers in Image"
Cause
The directory path where the image data is stored is not 8.3 compliant.
Solution or Workaround
Move the image to a directory that is 8.3 compliant, or rename the directory to be 8.3 compliant. Make sure the image file name is also eight characters or less.
For a file or path name to be 8.3 compliant, the prefix portion of the name must not be longer than 8 characters. The suffix portion of the name must be 3 characters long exactly. Additionally, the path or file name must not contain special characters, such as, spaces, #, $, and so forth.
Related Information
