ERROR
When using the Import71 utility to import ArcInfo interchange files (.e00), the following error occurs:
"This file cannot be accessed." Make sure you have security privileges on the drive.
There is not enough space on the drive and/or in the directory. A directory nearing 100MB may cause problems for ArcView saving to that directory.
Get help from ArcGIS experts
Download the Esri Support App
