English
Error: File cannot be loaded due to incompatibility in file format or projection information
Error Message
Launching the ArcView Projection Utility returns:
"File cannot be loaded due to incompatibility in file format or projection information."
Cause
There is a space or hyphen in the directory path name to the active theme in the view.
Solution or Workaround
Remove the space or hyphen from the path name.
Related Information
