HOW TO
This article contains sample code that adds a sequential identifier to sorted data.
Code in the Project's ThisDocument code module will only run in the current map document. If you want to store the code in all your map documents, open the Normal.mxt ThisDocument code module instead.
Code:
Sub AddSequentialIdsToSortedData()
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim player As ILayer
Dim pFLayer As IFeatureLayer
Dim pFClass As IFeatureClass
Dim pTableSort As ITableSort
Dim pTable As ITable
Dim pCursor As ICursor
Dim pRow As IRow
Dim pQf As IQueryFilter
Dim x As Long
Dim y As Long: y = 0
Dim pEditor As IEditor
Dim pID As New UID
Dim pDataset As IDataset
Set pMxDoc = ThisDocument
Set pMap = pMxDoc.FocusMap
Set player = pMap.Layer(0)
Set pFLayer = player
Set pFClass = pFLayer.FeatureClass
Set pTable = pFClass
Set pTableSort = New tablesort
Set pQf = New QueryFilter
With pTableSort
.Fields = "Name"
.Ascending("Name") = True
Set .QueryFilter = pQf
Set .Table = pTable
End With
pTableSort.Sort Nothing
Set pCursor = pTableSort.Rows
Set pRow = pCursor.NextRow
Set pDataset = pTable
pID = "esriCore.editor"
Set pEditor = Application.FindExtensionByCLSID(pID)
x = pTable.FindField("test")
Do Until pRow Is Nothing
y = y + 1
pRow.Value(x) = y
pRow.Store
Loop
End Sub
Get help from ArcGIS experts
Download the Esri Support App
