HOW TO
Programmatically get the current version from an SDE layer
Summary
This article shows how to get the version name for the first layer in ArcMap.
Procedure
  1. Start ArcMap.
  2. Open the Visual Basic Editor.
    In ArcMap, select Tools > Macros > Visual Basic Editor.
  3. In the Project Explorer window, expand Project.mxt and select ArcMap Objects > ThisDocument. Right-click and select View Code.
    [O-Image] Visual Basic Project  Explorer
    Code in ThisDocument module will only run in the current map document. To store the code in all your map documents, open the Normal.mxt ThisDocument code module.
  4. Copy the following into the code module.
    Code:
    Sub GetVersion()
    'Returns the version for the
    'first layer in ArcMap
    Dim pDoc As IMxDocument
    Set pDoc = ThisDocument
    Dim pLayer As IFeatureLayer
    Set pLayer = pDoc.FocusMap.Layer(0)
    Dim pDataset As IDataset
    Set pDataset = pLayer.FeatureClass
    Dim pVersion As IVersion
    Set pVersion = pDataset.Workspace
    MsgBox pVersion.VersionName
    End Sub
  5. Close the Visual Basic Editor.
  6. Run the code.
    A. Click Tools > Macros > Macros to display the Macros dialog box.
    B. Select a macro and click Run.
Article ID:000004953
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
