HOW TO
This article shows how to use IApplication::CurrentTool to make a UIToolControl the active tool in ArcMap.
Code in ThisDocument module will only run in the current map document. To store the code in all your map documents, open the Normal.mxt ThisDocument code module.
Code:
Sub SetCurrentTool()
Dim pCommandItem As ICommandItem
Dim pApp As IApplication
Set pApp = Application
Set pCommandItem = Project.ThisDocument.CommandBars.Find("Project.UIToolControl1")
Set pApp.CurrentTool = pCommandItem
End Sub
Get help from ArcGIS experts
Download the Esri Support App
