HOW TO
This article describes how to access joined fields of a feature layer. Joined fields are contained in the display table.
Code in ThisDocument module will only run in the current map document. To store the code in all your map documents, open the Normal.mxt ThisDocument code module.
Code:
Sub AccessJoinedFields()
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pFeatureLayer As IFeatureLayer
Set pFeatureLayer = pDoc.FocusMap.Layer(0)
Dim pFeat As IFeature
Set pFeat = pFeatureLayer.FeatureClass.GetFeature(12)
Dim pTable As ITable
Dim pDisplayTable As IDisplayTable
Set pDisplayTable = pFeatureLayer
Set pTable = pDisplayTable.DisplayTable
Dim pFields As IFields
Dim pField As IField
Set pFields = pTable.Fields
For i = 0 To pFields.FieldCount - 1
Debug.Print pFields.Field(i).Name
End Sub
Get help from ArcGIS experts
Download the Esri Support App
