English
Error: Unknown Object "DocAct.5" in Project
Error Message
Attempting to open an ArcView project from version 3.1, 3.2, or 3.2a in 3.0a or 3.0b returns the following error:
Cause
The project was saved in version 3.1 or 3.2 with the Dialog Designer extension loaded. The Dialog Designer extension was not packaged with ArcView 3.0a or 3.0b. 'DocAct' is a Dialog Designer extension object and requires that the extension be loaded.
Solution or Workaround
  1. Download the Dialog Designer Extension for ArcView 3.0a or 3.0b.
    See Related Information.
    ArcView 3.0a is for Windows and Power Macintosh and 3.0b is for UNIX.
  2. Install the Dialog Designer Extension. Installation instructions are given on the web site.
Related Information
