English
Error: Unsupported char encoding
Error Message
** Fixed at ArcSDE 8.2 **
Making a connection to an ArcSDE server using Microsoft's VJ++ returns the error:
"Unsupported char encoding"
Cause
This error is returned when the ArcSDE Java application programming interface (API) attempts to use encoding libraries not available in Java Virtual Machine (JVM) 1.1.
VJ++ uses JVM version 1.1. Sun renamed the character encoding libraries at JVM version 1.1.6.
Solution or Workaround
Use Java Virtual Machine version 1.2.2 or higher.
