English
Problem: When running the ZonalStats function at the Grid prompt, 'Fatal Error' occurs
** Fixed at ArcGIS 8.2 **
This error occurs when running the ZonalStats function at the Grid prompt:
"Fatal Error"
Cause
This is a known problem with large input grid datasets.
Solution or Workaround
This is issue has been resolved in ArcGIS Version 8.2.
In previous versions:
Run ZonalStats to calculate only one statistic to save memory space:
Code:
Grid: output = zonalstats(zonegrid, griddataset, mean)
