English
FAQ: What GRID functions can be used in the Raster Calculator?
Question
Answer
The following GRID functions can be accessed with the Raster Calculator:
ABS			FOCALMIN		ROTATE
ACOS FOCALMINORITY SAMPLE
ACOSH FOCALRANGE SELECT
AGGREGATE FOCALSTD SELECTBOX
ASCIIGRID FOCALSUM SELECTCIRCLE
ASIN FOCALVARIETY SELECTMASK
ASINH GREATERTHAN SELECTPOINT
ASPECT GRIDASCII SELECTPOLYGON
ATAN GRIDFLOAT SETNULL
ATAN2 GRIDLINESHAPE SHAPEGRID
ATANH GRIDPOINTSHAPE SHIFT
BASIN GRIDSHAPE SHRINK
BLOCKMAJORITY HILLSHADE SIN
BLOCKMAX HSV2BLUE SINH
BLOCKMEAN HSV2GREEN SINK
BLOCKMEDIAN HSV2RED SLICE
BLOCKMIN IDW SQRT
BLOCKMINORITY INT STD
BLOCKRANGE ISNULL SLOPE
BLOCKSTD KRIGING SNAPPOUR
BLOCKSUM LESSTHAN SPLINE
BLOCKVARIETY LINEDENSITY SQR
BOUNDARYCLEAN LINEDIRECTION STREAMLINK
BUILDSTA LINEDIST STREAMORDER
BUILDVAT LINESTATS STREAMSHAPE
CEIL LN SUM
COMBINE LOG10 TAN
CON LOG2 TANH
CONTOUR LPOS TEST
CORRIDOR MAJORITY THIN
COS MAJORITYFILTER TREND
COSH MAKESTACK UPOS
COSTALLOCATION MAX VARIETY
COSTBACKLINK MEAN VISIBILITY
COSTDISTANCE MED WARP
EUCALLOCATION MERGE WATERSHED
EUCDIRECTION MERGEVAT ZONALAREA
EUCDISTANCE MIN ZONALCENTROID
EXP MINORITY ZONALFILL
EXP10 MIRROR ZONALGEOMETRY
EXP2 MOSAIC ZONALMAJORITY
EXPAND NIBBLE ZONALMAX
FLIP NORMAL ZONALMEAN
FLOAT PATHDISTANCE ZONALMEDIAN
FLOATGRID PICK ZONALMIN
FLOOR POW ZONALMINORITY
FLOWACCUMULATION RAND ZONALPERIMETER
FLOWDIRECTION RANGE ZONALRANGE
FLOWLENGTH RANK ZONALSTATS
FMOD RECLASS ZONALSTD
FOCALFLOW REGIONGROUP ZONALSUM
FOCALMAJORITY RESAMPLE ZONALTHICKNESS
FOCALMAX RGB2HUE ZONALVARIETY
FOCALMEAN RGB2SAT
FOCALMEDIAN RGB2VAL
See the 'Spatial Analyst Functional Reference' for information on how to use each supported Spatial Analyst function. This Functional Reference is available in ArcGIS 8.2, via the online Desktop Help system (open the Spatial Analyst book in the table of contents and click the link 'Spatial Analyst Functional Reference'). To access the Functional Reference from the Raster Calculator click the 'About Building Expressions' button on the Raster Calculator then click 'Functional Reference for Spatial Analyst Functions.' Click 'Map Algebra syntax' within a topic to access information on usage, parameters and examples.
With ArcGIS 8.2, to obtain usage information for Spatial Analyst functions, type the function into the Raster Calculator, select it, right-click and click Usage.
In ArcGIS pre-8.2, with Workstation installed, information on these functions is available in ArcDoc.
