English
Error: Adding a data table with SQL Query wizard causes a Segmentation Violation
Error Message
This error occurs when using the SQL Query wizard to add a database table:
Error:
"Segmentation Violation"
Cause
This is a known issue with Database Access version 2.1c.
Solution or Workaround
Use the Add Database Table dialog box instead of the SQL Query wizard.
  1. Load the Database Access extension.
  2. Make the Project window active.
  3. Click Database Table Preferences from the Project menu.
  4. Select Add Database Table and click OK.
    [O-Image] Add Database Table dialog box
  5. Select Add Database Table from the Project menu.
Related Information
