English
How To: Use ArcObjects to convert VPF data to a geodatabase
Summary
The following sample code will convert a VPF dataset to a personal geodatabase dataset.
Procedure
  1. Open ArcMap.
  2. Create a new UIButtonControl: How To: Create a new UIButtonControl
     For more information on creating a UIControl, see the ArcGIS Desktop Help topic: 'Creating custom commands with VBA and UI Controls'
  3. Right-click the UIButtonControl and select View Source.
  4. Paste this code into the UIButtonControl's click event. Please note that changes will need to be made to path and file names in this code.
    Code:
    Sub vpf2gdb()
    ' This runs from ArcMap.
    'Set the InputWorkspaceFactory.
    Dim pInWorkspaceFact As IWorkspaceFactory
    Set pInWorkspaceFact = New VpfWorkspaceFactory
    'Create a PropertySet with which to open workspace.
    Dim pInPropSet As IPropertySet
    Set pInPropSet = New PropertySet
    pInPropSet.SetProperty "database", "E:\WORK\UVMAP\UVMAP"
    'Open Workspace.
    Dim pInWorkspace As IWorkspace
    Set pInWorkspace = pInWorkspaceFact.Open(pInPropSet, 0)
    Dim pFeatWorkspace As IFeatureWorkspace
    Set pFeatWorkspace = pInWorkspace
    'Open the Feature Dataset.
    Dim pFeatDataset As IFeatureDataset
    Set pFeatDataset = pFeatWorkspace.OpenFeatureDataset("baydhabo:trans")
    'Set Dataset Name.
    Dim pInDatasetName As IDatasetName
    Set pInDatasetName = pFeatDataset.FullName
    'Set up the Output WorkspaceFactory.
    Dim pOutWorkspaceFactory As IWorkspaceFactory
    Set pOutWorkspaceFactory = New AccessWorkspaceFactory
    Dim pOutPropSet As IPropertySet
    Set pOutPropSet = New PropertySet
    pOutPropSet.SetProperty "Database", "e:\work"
    'Create output WorkspaceName.
    Dim pOutWorkspaceName As IWorkspaceName
    Set pOutWorkspaceName = pOutWorkspaceFactory.Create("e:\work", _
            "VPFtoGDB", pOutPropSet, 0)
    Dim pOutFeatDatasetName As IFeatureDatasetName
    Set pOutFeatDatasetName = New FeatureDatasetName
    Dim pOutDatasetName As IDatasetName
    Set pOutDatasetName = pOutFeatDatasetName
    Set pOutDatasetName.WorkspaceName = pOutWorkspaceName
    pOutDatasetName.Name = pInDatasetName.Name
    'QI for IFeatureDatasetName
    Dim pFeatDatasetName As IFeatureDatasetName
    Set pFeatDatasetName = pInDatasetName
    Dim pEnumDS_FCName As IEnumDatasetName
    Set pEnumDS_FCName = pFeatDatasetName.FeatureClassNames
    Dim pDS_FCName As IDatasetName
    Set pDS_FCName = pEnumDS_FCName.Next
      'Convert each featureclass in enumeration.
      Do While Not pDS_FCName Is Nothing
        'QI for IFeatureClassName
        Dim pFeatClassName As IFeatureClassName
        Set pFeatClassName = pDS_FCName
        'QI for IName
        Dim pName As IName
        Set pName = pFeatClassName
        'Open FeatureClass
        Dim pFeatClass As IFeatureClass
        Set pFeatClass = pName.Open
        'QI for IDataset
        Dim pTempDataset As IDataset
        Set pTempDataset = pFeatClass
        'Use IFieldChecker to verify the field names are valid.
        Dim pFields As IFields
        Dim pValidatedFields As IFields
        Dim pFieldChecker As IFieldChecker
        'Get Fields from FeatureClass.
        Set pFields = pFeatClass.Fields
        Set pFieldChecker = New FieldChecker
        pFieldChecker.Validate pFields, Nothing, pValidatedFields
        'Create the new output. FeatureClassName object
        Dim pOutFeatClassName As IFeatureClassName
        Set pOutFeatClassName = New FeatureClassName
        'QI for IDatasetName
        Dim pOutDataset_FCName As IDatasetName
        Set pOutDataset_FCName = pOutFeatClassName
        'Set the Name of the FeatClassName.
        pOutDataset_FCName.Name = pTempDataset.Name
        Dim pFeatDataConv As IFeatureDataConverter
        Set pFeatDataConv = New FeatureDataConverter
        pFeatDataConv.ConvertFeatureClass pFeatClassName, Nothing, _
            pOutFeatDatasetName, pOutFeatClassName, Nothing, _
            pValidatedFields, "", 1000, 0
      Loop
    End Sub
