Executing clip, intersect, or union in the Geoprocessing wizard crashes ArcMap.
Cause
The amount of RAM and page file space exceed 2.1 gigabytes.
Solution or Workaround
- Have your system administrator identify the current amount of RAM being used on your machine.
- Subtract this value from 2.1 gigabytes. The difference is the maximum page file size you should use for all drives.
- Have your system administrator reset your page file size to the value calculated in Step 2.
