English
How To: Programmatically display selected features in ArcMap
Summary
If you are using VBA to select features in ArcMap, the code in this article will allow you to display those features.
Procedure
Use IFeatureSelection::SelectionSet on your selection set.
Code:
Dim pFSelection as IFeatureSelection
Set pFSelection = pFeatureLayer
Set pFSelection.SelectionSet = MySelectionSet
pFSelection.SelectionChanged
Dim pAV As IActiveView
Set pAV = pDoc.FocusMap
pAV.ScreenDisplay.Invalidate Nothing, True, pAV.ScreenCacheID(esriViewGeoSelection, Nothing)
