English
FAQ: How many parameters does the AUG_A datum transformation require?
Question
Answer
In ArcDoc, the AUG_A datum is listed as using a seven-parameter transformation. It is an update to AUG and uses a three-parameter transformation. The parameters are:
-128.5 -53.0 153.4
