PROBLEM
Creating a feature class from the XY table in ArcCatalog creates an empty feature class
Last Published: January 27, 2022
This article applies to retired ArcGIS versions 8.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
No features are added when using ArcCatalog to generate a point feature class in a geodatabase from a table of x,y coordinates. Features are added if a shapefile is specified for the output feature class.
Cause
This occurs because the XY domain of the output spatial reference is outside the bounds of the data.
This is not an issue for shapefiles because they do not have an XY domain.
Solution or Workaround
When specifying the output in the Create Feature Class from XY Table dialog box, it may be necessary to set the XY domain.
  1. Click Output Geometry Options.
  2. Click Edit in the Spatial Reference data frame.
  3. Click the X/Y Domain tab and set the appropriate X and Y domains.
Article ID:000004870
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
