English
Problem: SE_stream_execute (-41) invalid column value
When using the sderaster command to import raster data into ArcSDE, the following message is returned:
SE_stream_execute (-41) invalid column value using sderaster command
example: sderaster -o import -l zeelandjpg,image -f 3001022.tif -u ernst -p ernst -c jpeg -G 28992 -g
Connecting to server logbx0324, default instance, as user ernst
Creating user table: zeelandjpg
Creating raster layer: zeelandjpg.image
Image Dimension..............: 1778, 1185, 1
Pixel Type...................: 4bit
Image Extent.................:
minx : 24000.00000000000000
miny : 352016.00000000000000
maxx : 47989.50000000000000
maxy : 368000.00000000000000
Error: SE_stream_execute (-41)
Error: Invalid column value
Incomplete...
Cause
JPEG compression is supported on 8-bit single band or multiband images and is an available option for the sderaster command and ArcObjects.
An 8-bit thematic image was initially used, and that didn't work.
Solution or Workaround
To store it in JPEG format, an 8-bit thematic image would have to be converted to a 24-bit image.
