English
Problem: PROJECTDEFINE doesn't work on grid stacks
The PROJECTDEFINE function doesn't work on grid stacks.
Cause
The PROJECTDEFINE function, like all projection commands, does not work with stacks.
Solution or Workaround
The projection of a stack is taken from the first added grid that has a defined projection.
  1. Create a new stack.
  2. Make sure the first grid you add has the intended projection.
