Frequently asked question
If any neighborhood cells are NoData, they are assigned the value of the center cell. An example of this is when the 3x3 window is on an edge of a raster.
Taking the illustration above, the rate of change in the x direction for cell ‘e’ is calculated with the following algorithm:
(dz/dx) = ((c + 2f + i) - (a + 2d + g)) / 8
For example:
(dz/dx) = ((85 + 170 + 84)) - (101 + 202 + 101)) / 8
(dz/dx) = -8.125
The rate of change in the y direction for cell ‘e’ is calculated with the following algorithm:
(dz/dy) = ((g + 2h + i) - (a + 2b + c)) / 8
For example:
(dz/dy) = ((101 + 182 + 84) - (101 + 184 + 85)) / 8
(dz/dy) = -0.375
Taking the rate of change in the x and y direction for cell ‘e’, aspect is calculated using:
aspect = 57.29578 * atan2 (dz/dy, -dz/dx)
For example:
aspect = 57.29578 * atan2 (-0.375, 8.125)
aspect = -2.64
The above aspect value is then converted to values ranging in the compass directions (0 - 360 degrees) according to the following rule:
if aspect < 0
cell = 90.0 - aspect
else if aspect > 90.0
cell = 360.0 - aspect + 90.0
else
cell = 90.0 – aspect
For example:
Aspect = -2.64
aspect < 0
Cell = 90.0 - aspect
Cell = 90 – (-2.64)
Cell = 90 + 2.64
Cell = 92.64
The aspect value of 92 for cell ‘e’ = East.
Reference
Burrough, P. A. and McDonell, R.A., 1998. Principles of Geographical Information Systems (Oxford University Press, New York), p. 190.
Get help from ArcGIS experts
Download the Esri Support App
