English
Error: Abnormal program termination!
Error Message
When trying to launch ArcMap, it fails with the error message:
"Abnormal program termination!"
Cause
The .MXT file associated with ArcMap has most likely become corrupted.
Solution or Workaround
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Delete the ArcMap template file, 'Normal.mxt'. It will be recreated the next time you start ArcMap.
  1. Navigate to the ArcMap Templates directory.
    • Windows NT:
C:\WINNT\Profiles\<your_user_account>\Application Data\Esri\ArcMap\Templates
  • Windows 2000:
C:\Documents and Settings\<your_user_account>\Application Data\Esri\ArcMap\Templates
  1. Delete 'Normal.mxt' from Templates.
  2. Start ArcMap again.
Related Information
