HOW TO
This sample code performs the same functionality as the Switch Selection button in ArcMap.
Code in ThisDocument code module will only run in the current map document. To store the code in all map documents, open the Normal.mxt ThisDocument code module.
Code:
Sub SwitchSelection()
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pMap As IMap
Set pMap = pDoc.FocusMap
'Get the Feature Selection
Dim pFLayer As IFeatureLayer
Set pFLayer = pMap.Layer(0)
Dim pFSel As IFeatureSelection
Set pFSel = pFLayer
'Get the set of selected features
Dim pSelFeats As ISelectionSet
Set pSelFeats = pFSel.SelectionSet
Debug.Print "Selected Features " & pSelFeats.Count
'Get a selection set of all features
Dim pAllFeats As ISelectionSet
Set pAllFeats = pFLayer.FeatureClass.Select(Nothing, _
esriSelectionTypeIDSet, esriSelectionOptionNormal, Nothing)
Debug.Print "Total Features " & pAllFeats.Count
'Switch the Selection
Dim pNewSel As ISelectionSet
pAllFeats.Combine pSelFeats, esriSetDifference, pNewSel
Debug.Print "New Selection " & pNewSel.Count
Set pFSel.SelectionSet = pNewSel
pDoc.ActiveView.Refresh
End Sub
Get help from ArcGIS experts
Download the Esri Support App
