English
FAQ: What methods are available to restrict ArcMap clients from accessing ArcIMS map services?
Question
Answer
There are several methods you can use to limit ArcIMS map service access from ArcMap, and other ArcXML-capable clients, including ArcExplorer 3+ and ArcPad. These methods are described in the ESRI whitepaper titled "How To Manage the Data Sharing Capabilities of an ArcIMS Map Service". A link to this whitepaper is available in the Related Information section below.
Keywords: export copy lock security alias servlet connector transfer shapefile data
Related Information
