English
Problem: Labels do not display in a projected map
Labeling a map that is projected sometimes does not display any labels.
Cause
This is a known issue. The map contains a geodatabase annotation layer that has a feature weight greater than none. This prevents labels from being placed on the map.
Solution or Workaround
Make sure the feature weight for the annotation layer is set to none.
  1. Right-click on the map and select Properties.
  2. Switch to the Labels tab.
  3. Click the Conflict Detection Rules button.
  4. For each annotation layer, right-click the Feature Weight column and select None.
    Conflict Detection Rules dialog box used for labeling. Invoke from Data Frame Properties Labels tab.
    [O-Image] Conflict Detection Rules dialog
