English
Problem: FATAL ERROR Attempted write past end of file
Editing or saving a file in ArcInfo or ArcEdit returns:
"FATAL ERROR Attempted write past end of file."
Cause
Data is accessed over a network and errors are detected in the data by ArcInfo.
Solution or Workaround
If you are working with data over a network, copy the data locally to the machine running ArcInfo.
To determine what machine is running ArcInfo, type the following:
UNIX
Arc: &sys echo $ARCHOME
Windows NT or 2000:
Arc: &sys echo %ARCHOME%{\NOTE}
