English
Error: Fatal Error (VREADR)
Error Message
Running BUILD or CLEAN against a coverage causes a Fatal Error (VREADR) to occur.
Cause
Required temporary files are not available.
Solution or Workaround
  • Set ARCTMPDIR to a directory on the drive where ArcInfo is installed,
    If Arcinfo is installed in d:\arcexe80,
    set ARCTMPDIR to d:\tmp. Make sure tmp exists.
  • Install the Geoprocessing Server on the machine hosting the data.
