English
Error: Warning: The (extension) license has expired
Error Message
When starting ArcGIS, an error message is displayed noting that one or more licenses have expired. For example:
Warning: The ArcPress (ArcPress) license has expired.
Warning: The Geostatistical Analyst (GeoStats) license has expired.
Warning: The 3D Analyst (TIN) license has expired.
Warning: The Spatial Analyst (Grid) license has expired.
Warning: The StreetMap USA (StreetMap) license has expired.
Cause
The license or licenses listed in the error message have expired and may block the use of existing, non-expired licenses from working properly.
Solution or Workaround
The best solution is to delete the expired licenses. The expired license messages can also just be suppressed, however, expired licenses can causes problems for valid licenses.
  • Remove the expired license files
    1. On the computer where the license manager is installed, start Windows Explorer and navigate to the license manager install location. By default, this is located at C:\Program Files\ESRI\License or \ESRI\License\ArcGIS9x.
    2. Delete any and all expired licenses .LIC files
    3. Restart the license service in LM Tools or reboot the computer.
    Don't delete any license files with an expiration date of 01-jan-00; this indicates the license has no expiration date.
  • Suppress the license expiration warnings.
    See the link in the Related Information section for information on this procedure.
Related Information
