English
Problem: Scalebar and theme legend values have extra zeros to the right of the decimal
The values on layout scalebars and numeric classes in a theme's legend have
decimals after the integer followed by six zeros, even though the values fields
in the attribute table have integer values.
Cause
Conflict with ArcView and the default printer driver.
Solution or Workaround
Install an updated driver for the default printer, or set another printer to be the system default. You can obtain an updated printed driver from the manufacturer's Web site.
