English
Error: Avarray index 687 not in range 0..686
Error Message
This error occurs when trying to load a view into a layout:
"Avarray index 687 not in range 0..686"
Cause
Corrupt shapefile in the view.
Solution or Workaround
Try one of the two methods below to resolve the problem.
If you have more than one shapefile, delete all but one. Add the view to a layout and see if the error occurs. Repeat and cycle though all the shapefiles until you find the offending one.
