English
Problem: ArcInfo Print does not open when double-clicking a .gra file
Double-clicking a file with a .gra extension does not open the file into the ArcInfo Print GUI.
Cause
The association of .gra files as ESRI print documents is removed after installing Office 2000.
Solution or Workaround
Redefine the .gra association as a print document.
  1. Click the .gra file to highlight it, using a single left-click.
  2. Hold down the Shift key, right-click the .gra file, and select Open With.
  3. Check the box labeled 'Always use this program to open files of this type'.
  4. In the list of programs, select 'ArcPress for ArcInfo' or 'Winpress.'
  5. Click OK.
