English
Error: FATAL:java.net.BindException: Address in use
Error Message
When attempting to run startup.bat from <drive>:\jakarta-tomcat-3.2\bin, the following error message occurs:
FATAL:java.net.BindException: Address in use: bind
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:390)
at java.net.ServerSocket.<init>(ServerSocket.java:173)
at java.net.ServerSocket.<init>(ServerSocket.java:124)
at org.apache.tomcat.net.DefaultServerSocketFactory.createSocket(Default
ServerSocketFactory.java:97)
at org.apache.tomcat.service.SimpleTcpEndpoint.startEndpoint(SimpleTcpEn
dpoint.java:186)
at org.apache.tomcat.service.SimpleTcpConnector.start(SimpleTcpConnector
.java:142)
at org.apache.tomcat.core.ContextManager.start(ContextManager.java, Comp
iled Code)
at org.apache.tomcat.startup.Tomcat.execute(Tomcat.java:157)
at org.apache.tomcat.startup.Tomcat.main(Tomcat.java:163)
Cause
Another application or service is already accessing port 8080. On Windows, it could be a service installed on some Dell servers. The service name is 'dellw3j' and it uses port 8007.
Solution or Workaround
  1. Stop the service that is using port 8080.
    See Related Information to download fport v1.33. This program reports all open TCP/IP and UDP ports and maps them to the owning application.
  2. Rerun startup.bat.
Related Information
