English
Problem: Excessive memory consumption when creating TINs
When constructing or using TINs that have large node or triangle tag values, for example, values that are in the millions, a large amount of system memory is used as well as the creation of some large xx* files on disk.
Cause
This is a known issue with version 8.1.2.
Solution or Workaround
This issue has been fixed for version 8.2.
