English
Bug: Interpolate Line and Polygon tools not working when surface projected on the fly
** Fixed at ArcGIS 8.2 **
The line and polygon interpolation tools fail to produce output when the map display is in a different projection system than the surface.
Cause
This is a known problem.
Workaround
There is no workaround.
