PROBLEM
When a connection to an Oracle database is made using the Oracle 8.1.7 OLE DB provider, the content of all numerical fields display as zero in ArcGIS applications.
This is a known issue with the Oracle 8.1.7 OLE DB provider.
Use the Oracle 8.1.7 ODBC driver or the Oracle 8.1.6 OLE DB provider to make the connection to the database.
Get help from ArcGIS experts
Download the Esri Support App
