English
Problem: The Zoom In tool works to a certain point but then it will not zoom in any further
After zooming in on a data set, to a very large scale, dragging a box on the Data View using the Zoom In tool no longer zooms in on the data.
Cause
You have reached a threshold scale of the data. The threshold is based on the extent of the data. For example, you're zooming to an extremely small section of a data set with a large extent.
Solution or Workaround
Either of these methods allow you to zoom in further:
  • Single-click the Zoom In tool in the center of the area you would like to view.
  • Click the Fixed Zoom In tool.
