ERROR
Error executing stored procedure: db2gse.gse_unregist_layer SDE_Database Error: 0
Error Message
When attempting to delete a layer this error may occur:
"Error executing stored procedure: db2gse.gse_unregist_layer SDE_Database Error: 0"
Cause
This is a known issue. This error only occurs on the Windows platform because the fix that was needed is not available at FixPack3 on Windows but it is present for AIX. FixPack 4 on AIX and NT contain both the fixes.
Solution or Workaround
Upgrade to DB2 UDB FixPack 4. The link below will lead you to IBM Technical Support where you can navigate to this FixPack 4.
    Article ID:000004663
    Software:
    • Legacy Products
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
