PROBLEM
Color schemes for unique values legends assign the incorrect colors to each classification in the legend. For example, the color scheme 'Autumn Leaves' assigns green, blue, white, or yellow colors instead of shades of reds and oranges.
The odb file that stores the color schemes is corrupt.
Warning: Be sure to copy to a temporary directory any projects, data, scripts, and extensions that may reside in the ArcView home folder. This folder is called ESRI by default.
Note: The uninstall process does not remove this folder.
Get help from ArcGIS experts
Download the Esri Support App
