HOW TO
Use special characters as text in ArcView
Summary
Special characters. such as ®, ©, and others. are not accessible through standard keyboard strokes. You can get these characters into ArcView from the Windows Character Map utility. The script window cannot display these characters.
Procedure
With ArcView running:
  1. Start the Character Map utility. It may be under Start > Programs > Accessories, or Start > Programs > Accessories > System Tools.
  2. Set the Font to Times New Roman.
  3. Click the special character you want.
    [O-Image] Windows NT Character Map - normal mode.
    The keystroke sequence equivalent for the character will appear on the bottom right of the utility. You can use this sequence in ArcView to type that character directly. For example, hold the Alt key down and using the numeric pad type 0169 to enter the © character.
  4. Click the Select button. The character will be displayed in the Character to Copy field.
  5. Highlight and copy the character.
  6. Paste the character into ArcView.
    In ArcView, some fonts such as Wingdings, will display as the keystroke equivalent in the Text Properties box, but will appear as the symbol in the view or layout. For example, with the Wingdings font, type Alt+Q. A letter Q will appear in the Text Properties box, but an airplane character will show in the view.
Article ID:000004648
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
