English
How To: Transform the coordinate location of a CAD file using a rotate, scale, translate transformation
Summary
Instructions provided describe how to transform the coordinate location of a CAD drawing using a rotate, scale, translate transformation. This type of transformation requires two pairs of x,y coordinate values: one pair of From x,y coordinates and one pair of To x,y coordinates.
Procedure
  1. Start ArcMap.
  2. Load the CAD dataset.
  3. Right-click the CAD layer and select Properties.
  4. Click the Transformations tab.
  5. Click Enable Transformations.
  6. Click the Rotate, Scale, Translate option in the Transform By box.
  7. Type the From and To coordinate values.
  8. Type the Angle value.
  9. Type the Scale value.
  10. Click OK.
