English
Error: Error executing stored procedure: db2gse
Error Message
Trying to delete a view results in the following error -
"Error executing stored procedure: db2gse gse_unregist_layerSDE_Database
Error: 0
00000
ODBC Error: 00000
Database Error: -11
Error Message: GSE0011E Spatial Extender could not disable or unregister object "".
SQLSTATE=00000
msg_code: -11"
Cause
This is a known issue with spatial extender.
Solution or Workaround
To delete a view, the you must be the db2 admin user and issue the following command:
db2 delete from db2gse.gse_layer where layer_table ='<view-name>'
Click on the link below for more information and a fixpack that is available through IBM technical support.
    Related Information
