English
Error: Loading Table Data. Could not load data from the data source. If you can correct the problem, press refresh button to reload data
Error Message
This article refers only to ArcGIS Desktop versions 9.3.1 and earlier. For ArcGIS 10 and later, please refer to knowledgebase article 43077.
The error message, "Loading Table Data. Could not load data from the data source. If you can correct the problem, press refresh button to reload data", occurs by doing one of the following:
• After joining a table to a shapefile, and opening the attribute table of the shapefile.
• After creating an XY event layer from a dbf table, and opening the attribute table of the XY event layer.
Cause
The most common cause of this error is when the name of the object begins with a number, contains a space, or contains a special character. This includes:
• The name of the shapefile
• The name of the table
• A field name in a table
Solution or Workaround
Rename the file or field to omit the invalid character(s). After the file or field have been renamed, the table join must be reestablished.
Related Information
