English
Error: forrtl: severe (64): input conversion error, unit -5, file Internal Formatted
Error Message
Using the Import command at the Arc prompt with an ArcInfo interchange (.e00) file produces the following series of error messages.
forrtl: severe (64): input conversion error, unit -5, file Internal Formatted Re ad
Image PC Routine Line Source
DFORRT.dll 6112A7A9 Unknown Unknown Unknown
DFORRT.dll 6112A598 Unknown Unknown Unknown
DFORRT.dll 61129724 Unknown Unknown Unknown
DFORRT.dll 6112999F Unknown Unknown Unknown
DFORRT.dll 6114383D Unknown Unknown Unknown
convexport.exe 0040569F Unknown Unknown Unknown
convexport.exe 004155A7 Unknown Unknown Unknown
convexport.exe 004010B9 Unknown Unknown Unknown
convexport.exe 007F30E9 Unknown Unknown Unknown
convexport.exe 007F2F53 Unknown Unknown Unknown
KERNEL32.dll 77F1BA3C Unknown Unknown Unknown
Bailing out of CONVEXPORT
Program failed to start or was killed
Cause
The interchange file may contain an invalid node coordinate value. For example, a corrupted XY coordinate pair may look like the following.
1.20539621500000E+07 3.59q9564800?000E+06ì
The Y coordinate value above, is not a valid number because it contains non numerical characters.
Solution or Workaround
Open the interchange file in a text editor. Examine the file for bad coordinates.
Change any invalid coordinate values to zero.
Once you have imported the coverage, correct the coordinate value of the feature you edited in ArcEdit.
