ERROR
FATAL ERROR (MATNOD) Unable to delete old NAT
Error Message
Building nodes for a coverage that was imported from an ArcInfo Interchange file (.e00) at the Arc prompt produces the following error message.
ISP channel# 1 was not properly closed (INFEND)
ISP channel# 2 was not properly closed (INFEND)
ISP channel# 4 was not properly closed (INFEND)
Bailing out of RENODE
Cause
The ArcInfo interchange file contains invalid coordinates for one of the nodes in the file. For example, the Y-coordinate contains invalid alpha characters:
1.20539621500000E+07 3.59q9564800?000E+06ì
Solution or Workaround
  1. Open the interchange file in a text editor, and change the invalid coordinate values to zero.
  2. Import the coverage.
  3. Build node topology.
  4. Correct the node value in ArcEdit
Article ID:000004573
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
