ERROR
This error occurs while creating a service area with ArcView's Network Analyst extension, and attempting to set the cost field in the problem definition dialog box to something other than the default <Line Length>:
"Error reading impedance value"
Null data values in a numeric field of the ArcInfo coverage were used as the street theme.
The working units are those you'll specify the travel time or distance under the costs column in the problem definition dialog.
Get help from ArcGIS experts
Download the Esri Support App
