PROBLEM
When performing a join between the cover# field and a field that is indexed, no data is transferred for records that contain ***** as the value in the cover# field.
ArcView uses the displayed values, not the stored values, of the destination table to match to the values of an indexed field in the source table.
For further information see the ArcView online Help topic "Create/Remove Index".
Warning:
Back up your coverage before you perform any edits to this field.
Get help from ArcGIS experts
Download the Esri Support App
