HOW TO
Increase the resolution and quality of an image exported from ArcView
Summary
You can alter the resolution (dots per inch [dpi]) and quality of some images you export from ArcView.
Procedure
  1. Open the View or Layout.
  2. Select Export from the File menu.
  3. Click the Options button.
    If the Options button is not available, you cannot make any adjustments to the selected image format.
  4. Make the desired adjustments.
    The higher the dpi and quality, the larger your output file.
Article ID:000004561
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
