PROBLEM
Opening the extensions dialog box takes minutes.
The USEREXT directory contains a lot of data. When you open the extensions dialog box, ArcView checks this directory for extension files. If there is a lot of data in this directory, or sub-folders, it takes a long time for ArcView to look at all the files.
See the ArcView online help topic USEREXT for directions on how to set this variable.
Get help from ArcGIS experts
Download the Esri Support App
