Error Message
Saving an ArcView project, returns this error:
"Unable to write <path name>"
Clicking the OK button returns this message:
"Segmentation Violation"
Cause
The drive or the specific folder you are trying to save to is full.
Solution or Workaround
Do one of the following:
- Change your HOME and TEMP environment variables to a different drive and/or directory.
For help with setting a system environment variable, see: How To: Edit an environment variable. - Delete or move files to increase the space on the drive and/or folder used by your HOME and TEMP environment variables.
